Some history first, steam holes have to be drilled in the early blocks to match newer style heads, per Edelbrocks clear instructions.
He built my motor last year in October, pretty much refused to drill the holes in my block required by Edelbrock to keep the engine cool. He told me he didnt see the since in drilling the holes, but I told him at the time I figured Edelbrock knew better then him.
Since then I have added a 3 inch thick Griffin aluminum radiator ($740 delivered to the door), a $180 Edelbrock high performance water pump, and a milodon thermatstat at $20, trying to keep my motor cooled down. It still heats up to 220 (or more dont know cause I kill the motor every time) so nothing I`ve done has helped the problem.
I called Edelbrock tech line, they told me the repercusions for not drilling the steam holes would be a motor that would overheat........
This was my 2nd call today to my engine builder complaining about my overheating problem, told him I`d just added the new aluminum radiator and hp water pump and it didnt help much at all. He told me to tear the heads off and bring him the car, which I told him was unacceptable being as I had already thrown over $1000 at a problem he created and wasn`t fixing to touch this motor again.
I`m going to see him Monday morning, and I`ve already explained to him he was going to fix this willing or not, being as he caused the problem to start with.
Here is my point to this post guys, IF YOUR INSTALLATION INSTRUCTIONS FOR YOUR HEADS CALL FOR STEAM HOLES TO BE DRILLED INTO YOUR BLOCK AND YOUR BUILDER DONT WANT TO DO IT, FIND ANOTHER ONE. I`ve have a car that since it has gotten over 90 degrees outside I cant drive for more then 10 miles at a time, or it overheats.
If anyone has any advice on how I should present myself monday, please help me, cause I`d red in the face over this, and could use any thing yall can give me.
and not turning the fan on.
I know it's gone past 250 a couple times. The fan is wired with a manual switch. One day I may install an auto switch.
High temps don't harm anything as long as the coolant doesn't reach the boiling point. That point is determined by the water/antifreeze mix and the pressure rating of the cap.
