Maybe not a surging problem...
KcMstang
1,563
Hamilton, Georgia
I was driving the car last night after the tune up and got on the highway about 70mph. I noticed that the car wasn't surging because the RPMs weren't jumping they were very constant at 2k in 5th gear. I'm thinking what made me think the car was surging could be the exhaust leak...any other ideas?
A vacuum gauge would be useful to determine if the engine was changing load. The gauge would show a change in vacuum in unison with the suspected surge.
See the following diagram for the MAF location:
What the MAF assembly looks like up close
The MAF calibration must match the injectors unless you have a custom burned chip for the computer. The 24 lb injectors will have blue plastic tops.
Since having the BBK CAI I'm NOT 100% sure if it is Mass Air or Speed Density. I'm going to guess that it has been swapped to Mass Air since I believe I see the Mass Air Flow Sensor near the cone filter on my motor...am I right???
If so how would I go about seeing if my MAF is calibrated for the 24# injectors? Appreciate all the help and the pic...definitely saving that for future reference.
You are mass air - I see the MAF.
The cone filter in the engine compartment is a surge inducer. The air turbulance from the fan upsets the airflow though the MAF. That causes a surge. The fix is to mount the cone filter in the wheel well. If you are good with metal work, you can make a baffle that surrounds it and keeps the hot engine compartment air away from it.
By the way, the picture was a major clue in diagnosing your problem.
