I've decided to re-install the original power brake booster before I put the engine back in. I had been using the largest bore MC Strange makes (1.125 IIRC) with a manual pedal. It was fine for most situations, but one day the traffic came to a sudden stop, and I stood on the pedal with all my might and almost crashed into the car in front of me. I may have been able to solve the problem by going with a smaller bore (1.0625?) but I hated not using a perfectly good original booster, so I put it back on along with the matching power disc pedal and now need a new MC. The front calipers are 2 piston (about 1.6" dia) PBR units on 12.81" rotors while the rears have Wilwood discs. My problem is this: I can't find a master that will fit on the booster and has the bore sized right. I ordered a Master from MPB, but they sent a huge iron chunk that doesn't even come close to fitting in between the booster and the shock tower. I've got the engine ready to go back in and this is the only thing holding me up. I'm sure there are others out there with similar set-ups... anyone else using a stock Bendix booster with big front discs?
