mechanical water temp gauge - install question
  • Thread starter Thread starter enferno
  • Start date Start date Feb 21, 2007
enferno
418
  • Feb 21, 2007
i have a sunpro mechanical water temp gauge. on the sensor end, the fitting that screws into the intake manifold is hollow in the middle (for the sensor tube). my question is, am i missing a piece, or some method of installing this? is there a certain port that i need to screw this into? here are some pics of what i'm working with
my intake is an aluminum manifold from a 85 mustang
the sensor:
http://home.comcast.net/~enferno/DSC02677.JPG
the fitting:
http://home.comcast.net/~enferno/DSC02678.JPG
ports on the back right of the intake:
http://home.comcast.net/~enferno/DSC02679.JPG
port on the back left of the intake:
http://home.comcast.net/~enferno/DSC02681.JPG
current water temp sending unit port:
http://home.comcast.net/~enferno/DSC02680.JPG
thanks for your help!
gbarber
158
delaware, ohio
Feb 21, 2007
  • Feb 21, 2007
I installed a similar Summit gauge in one of the left rear ports on my Edelbrock intake. The sending unit on mine looks just like the one you have. I had to buy an adaptor at NAPA to match the thread of the sending unit to my intake.
enferno
418
  • Feb 21, 2007
mine threads in fine . . but what's going to keep the water from squirting out the hole in the fitting?
H
hsr
138
Riverview, MI USA
Feb 21, 2007
  • Feb 21, 2007
You have to use the adapter regardless of whether the threads fit or not. The inside of the adapter has a tapered seat for the probe to sit against and the threaded loose piece locks it down.
See attached.
C
Cobra ssc
80
Austin, TX
Feb 21, 2007
  • Feb 21, 2007
Don't use the sending unit on the rear ports of the intake manifold, coolant doesn't flow through there, only the front ones. You will not get accurate readings from there. FYI
enferno
418
  • Feb 21, 2007
oh i have one of those!
thanks for clearing it up!
gbarber
158
delaware, ohio
Feb 21, 2007
  • Feb 21, 2007
The rear ports may not have the flow that you would get from the front of the intake and may not be as accurate as the front, but I didn't want to move the factory sending unit. I couldn't get the plug out of the front passenger side. I was afraid going to break something trying to remove it, so I put it in the back. Thanks for the info on the flow.
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
Other Auto Tech Jun 24, 2024
Wallyman
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
