Megasquirt questions
droopie85gt
Hookers and Beer for life!
Dec 26, 2016
697
528
143
Cordova, TN
Ok, so I have decided to sell my 85 (or trade or gut it) and build a drag car. It needs to be extremely low buck. Going to run 2.3 turbo Lima. Pick up a couple of SVO/Merkur/or Turbo Coupe engines. Seriously want to see how much HP for how little money I can put out.
Some things that will help this game plan will be running E85. I found out there are 2 stations in the area...ONLY 2 in the entire Memphis area, but they are only about 20 miles away each.
Not sure, but I think I would like to run LS coil near plug setup, and maybe even meth injection on top of E85 to support a massive load of pressurized air molecules. I probably will blow a motor or 6 up, but that's ok.
My question is, right now I have a complete Holley HP TBI setup (used) in the box. Plan originally was to get the 4 cyl injector harness and use that. But, I could sell that to raise funds. Can I do everything with a MS2 or do I need a MS3. By everything, I mean LS coils, 2 step, maybe boost control, meth injection, and who knows what else.
Probably have a delay box on the two step for bracket racing, too.
So just wondering what's my shopping list to get on the MS train going to look like?
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
Let me see how many outputs would be available left over for something like a ms2pnp, I just got an extra one into my possession and could sell it for about half cost of new.
Or I have a diypnp for a honda, with some minor modifications it could easily be used in you application.
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
The StangNet MS Hookup, @a91what ? Sounds like you're the dealer and I'm the (soon to be) boost junkie!
Thinking about the PNP... is there an easy way to make a harness? If I use it on my 85, there is no factory efi harness. If I get another car, I will probably remove all the wiring and rewire only what is needed with new, non 30-40 year old wiring.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
yes there is an easy way, I have a rotunda harness you could use to splice it in. this way no mess on the factory harness...
alternative is to order a wiring bundle and plugs and build your own harness... there are also manufacturers that make aftermarket harnesses
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Good deal. I guess I have to start my online selling empire now to get rid of some of the stuff I acquired over the last 8 years for a Windsor swap.,
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
The wiring doesn't bother me. I am rewiring most everything under the hood already. When I swapped from Carb to Holley Commander 950, I had to make a fuel level sending unit out of parts to get the pre-87 resistance in EFI application, I carefully laid out the C950 harness and realized it would put the fuel pump relay outside of the tunnel (mounted ecu under seat) so I cut and resoldered a bunch to move it next to the ECU. I spliced in and cut out and moved a bunch of other stuff I don't remember now.
Funny thing is, I almost went MS2. I bought a used one, relay board, and Stim. At the time, wiring it all seemed kind of daunting. I found the NIB C950 about 7 or so years ago for a ridiculous price so I bought it and went with it. Mainly because it came with a 4bbl tbi. I was going to use a BBC 2bbl TBI to get it running with MS.
I was going to upgrade with Holley HP and stay 4bbl TBI. I am just going to wiring the MSD into the C950 and get everything under the hood wired back in and try to sell it.
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Let me know what you have that will work. I want to be sure I can implement launch control. I am listing my Holley HP setup for sale.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
Ok so the ms2pnp will be able to do semi sequential fuel and spark on a 4 cylinder. Coil packs doable in wasted spark (ls style) launch and boost control. With extra i/o available. If that's not enough I can build you an expansion card to give you all kinds of extra i/o.
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Let's see, what I want is launch control option, boost control will probably be manual since it's a drag car and not on the street, 4 injectors, 4 coils, a later model 2.3 will have crank and cam sensors and no dist. from the factory, so can I use those and get sequential injection? 2 electric fans, meth/water injection, I bought a couple of pressure transducers off ebay, thinking with the Holley I could log fuel pressure, and oil pressure. Not sure I need oil pressure just on a drag car. Oh, if I went with a dual plug 2.3 head could I do 8 LS coils? I'm trying to think of anything else I would possibly want to log or have as an input.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
I can get you setup with full sequential fuel and spark with the diypnp with a few mods, the 8 ls coils with be fired in pairs so no issue there. I can add an expansion card on the cheap and give you a huge amount of i/o.
to be honest full sequential is not that important for power production, batch fire or semi sequential will make just as much power, only cheaper. PM me if you want to talk over the phone
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Sounds good. When I get to the point of needing to acquire the MS, I'll let you know. Seems you're right. Batch fire will be fine and I probably do want boost control, now that I think about it. Why twist a knob under the hood, when I can key in instant destruction if needed.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
I will be putting the MS2pnp up for sale soon, the DIYPNP I am re-purposing as a TCU. figured i would give you a heads up since i offered it.
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Thanks! My HP hasn't moved yet, so I am in no rush. I think I want an MS3 just to have everything available to do whatever crazy :poo: I dream up.
Reactions: a91what
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
Hey @a91what is there a handy chart that shows the features available on the microsquirt, MS2, MS3? I am thinking of switching from the Holley to MS but for sure want launch control, flat shift control, maybe boost control and a meth/water control. It would control a TFI distributor to start. Batch fire. What are my options and do you have anything laying around to sell that would give me those?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
9,581
5,760
204
31
Hillsborough county
I do not have anything lying around as of right now, a simple microsquirt could do all the things you want at a very low price. However if you are going to spend money I suggest doing it one time, purchase a ms3x or start with an ms3 and you can upgrade easily in the future.
Are you wanting plug and play or are you going to wire it in? DIY has some charts showing functionality but as I said I would not buy less than an ms3
droopie85gt
Dec 26, 2016
697
528
143
Cordova, TN
It would all be wired in, there's no plug n play for my car. I finally found a chart of what MS version has these features. I may just get a microsquirt to start and could upgrade in the future and use it as a trans controller if I switch from manual to 4R70W, right?
Thread starter Similar threads Forum Replies Date
J Learning so much but still have some questions with megasquirt Digital Self-tuning Forum 1
Old Catman EFI and megasquirt questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
C 1995 Mustang GT Megasquirt Timing and ignition settings question Digital Self-tuning Forum 36
SlowFiveOh Megasquirt Tuning Questions Fox 5.0 Mustang Tech 5
lancec2c30 Megasquirt Ignition Question Fox 5.0 Mustang Tech 2
89Stang Tweecer/Anderson/Megasquirt questions. 2.3L (N/A & Turbo) Tech 1
G megasquirt trouble Digital Self-tuning Forum 2
B Megasquirt pnp2 maf wiring Digital Self-tuning Forum 3
Meo68 Megasquirt MSPNP2/94 Mustang 302 Digital Self-tuning Forum 14
GodStang Megasquirt MS3Pro Injector Swap Digital Self-tuning Forum 3
B Megasquirt wideband problem Digital Self-tuning Forum 12
M 93 foxbody 347 stroker megasquirt 2 pnp initial timing set up?? advice Digital Self-tuning Forum 6
C Megasquirt MSPNP2/95 Mustang 347 Digital Self-tuning Forum 0
C Megasquirt & Dirty Dirty Racing 1994 - 1995 Specific Tech 8
M Need help tuning megasquirt with kenne bell supercharger Digital Self-tuning Forum 9
atey950 89 5.0, Trick flow stage 1 h/c/i, Megasquirt pnp novice needs help Digital Self-tuning Forum 4
J Any benefits to running mass air with megasquirt? Digital Self-tuning Forum 3
W Autometer wideband with megasquirt pnp 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
S Megasquirt PNP2 460SBF startup/idle issues Digital Self-tuning Forum 9
beyondEOD Fuel Pressure Sensor with Megasquirt Digital Self-tuning Forum 15
S Using maf with megasquirt pnp Digital Self-tuning Forum 7
beyondEOD 94-95 Mustang GT Auto Dual Microsquirt ECUs Digital Self-tuning Forum 14
R Megasquirt installment 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
94Vortechcobra Connecting Wideband to Megasquirt PNP2 Digital Self-tuning Forum 2
DemonGT Holley Terminator X vs Megasquirt pnp2 Digital Self-tuning Forum 12
R ECU Tuning Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S Wide band reading vs megasquirt Digital Self-tuning Forum 6
HemiChall Ego Control setting for megasquirt with AEM wideband Digital Self-tuning Forum 14
S Megasquirt pnp idle issues Digital Self-tuning Forum 19
CHILL347 MegaSquirt PNP2 Outputs Digital Self-tuning Forum 5
L Need help with Megasquirt 331 HCI Digital Self-tuning Forum 12
9 MS2 Cold Start Issues Digital Self-tuning Forum 6
stanglx2002 Service Provided Megasquirt Digital Dash Services - Tuning, Welding, Mechanic, Body Work... 0
a91what Service Provided Megasquirt ECU support and Tuning Services - Tuning, Welding, Mechanic, Body Work... 5
M New guy here! turbo megasquirt The Welcome Wagon 1
Wilky-Medusa 2.0 Medusa Megasquirt.... help lol Digital Self-tuning Forum 118
Mazzzaaa 95 Mustang MegaSquirt tune or stock computer Chip tune? Digital Self-tuning Forum 19
B early bronco megasquirt pnp2 amortization thread Digital Self-tuning Forum 20
9 MegaSquirt 2 Digital Self-tuning Forum 26
stanglx2002 Megasquirt Digital Dash Digital Self-tuning Forum 45
Blucifer99 First start up using megasquirt.. 1992 5.0. Digital Self-tuning Forum 500
a91what Megasquirt tuning videos// what would you like to see explained in the software? Digital Self-tuning Forum 21
Blucifer99 92lx. Whats the difference between microsquirt and megasquirt for fox mustangs Digital Self-tuning Forum 10
Q For Sale Fox Vortech v-2, and megasquirt pnp ecm. Engine and Power Adder 1
S 1991 stock 5.0 on3 turbo megasquirt tuning. Digital Self-tuning Forum 31
vristang Talk Me Into Using Megasquirt? Digital Self-tuning Forum 7
stanglx2002 Progress Thread '88 GT Hell Horse - All over the place 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 448
a91what Megasquirt/tuner Studio Tech Thread Digital Self-tuning Forum 16
AUBURN1111 Digital Tuning Megasquirt 2 Pnp Basic Tune, 1st Time Install Fox 5.0 Mustang Tech 5
AUBURN1111 Megasquirt Pnp Install Fox 5.0 Mustang Tech 1
