mercury block?
pistonhead351
flim hunter
May 1, 2005
75
my buddy gave me a complete motor out of an 87 mercury grand marquis. it a 5.0 roller non h.o. i was just wondering if this is the same block, crank, rods they would have used in the mustang? i got the numbers but none of them match up to the numbers mustangs had. is it the same? ill get all the numbers if you guys need them.
All the internal parts are the same as the Mustang except for the cam and maybe the distributor.
Check the firing order, it may have an HO cam.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
