Sorry guys, long time no see, been busy with work, life and got myself a 2015 Ecoboost Premium a couple of months ago so not really wanted to work on my old junk
Anyway, today was the day I made it run! I remembered that when putting the engine back together, I had to fight with the installation of the throttle bracket and the throttle cable (which is pretty old and not very "tight" anymore -> to be replaced at some point) so I might have messed up the idle screw
So I went on to start the car, RPM shooting way up still, then went to the idle screw and turned until the RPM went steady... let it run a couple of minutes then disconnected the IAC, let it run, then turned it off, checked the TPS and reset to 0.98 (reset it also in TS).
Disconnected the battery a couple of minutes (even though I don't think it would be necessary with a MicroSquirt?)
Replugged the IAC and restarted the car.
Took a datalog
The thermostat works properly however it seems that when the car is warmed up the idle is getting a little bit more "choppy"... does anyone see something weird with the datalog?
Might be a good time for a tune
@a91what ?
