just thought i'd say thanks for all the help.....my pa performance power wire arrived today, 3g swap complete!
i still need to go back and do some routing with the power wire. it's a little extra long, which is good, but the in line fuse wont fit under the coil cover and i don't think it will fit under the battery tray...it came pre wired in line, so i may have to get an eyelet and make the wire a little shorter.
it said to hook the end to the selenoid that had the fuse on it, i assume you want the fuse closer to the selenoid for if the wire were to burn.....
i cut the stator wire off the black plug and just used a spade connector for now untill i get the proper plug. the rest of the plug, i just put a light coat of silicone on the end of it while everything was un hooked, so no moisture or water will get in it. i left it connected at the selenoid because that green wire with the fuse link , i read some where that has to be connected, then others have said i can disconnect it, so i'm still figuring that one out.
i used the stock pulley from the 2g, with a very very thin washer behind it to make the pulley alighn with all the others, belt tracks straight, and i now have about 14.5 volts idleing in neutral with every thing on ( a/c,lights, etc).......
the one thing i did notice though, is the pa performance instructions that came with the wire said to re-attatch the two black and orange stripe along with the new power wire, which ofcourse as i mentioned already, i did not, but thought i'd make a note of that......
thanks again for all the help......
