stangin it said:
If you have heads your rockers are Pedistal mount. I dont understand this adjusting valve train with pedistal style rockers. I have done mine 2 times once during head swap and once during the cam swap and i never did any of this **** i just bolted them down the car run great i just dont understand. I go to school for auto tech and i asked my teacher today he said that its non adjustable ( in my 94 GT ). Maybe we are both wrong but my experiances tell me other wise.
Im like you, I didnt use a single shim. If anything I needed longer pushrods or needed to grind down the pedistal. But I didnt do either, just put all of them on using the 1/2 a turn to 3/4 past zero lash and they worked fine and ive had them on for 2 years with no problems. They do chatter a little but the leaks from the headers were 10 times greater than whatever noise the rockers make.
Ok I'll give a run down of the 3 types of Roller Rockers:
Pedistal-Mount:offer the convience and affordability of bolting to stock and stock-style cylinder heads, but they offer little adjustability. The only way to compensatefor changes in valvetrain geometry is to install or remove shims beneath the pedistal mount. These rockers are an easy, cost effective way to add roller rocker arms to a street/strip 5.0.
Stud-mount:To install a stud mount roller rocker on a 5.0 cylinder head, the head must be designed or machined to accept it. Stud mount rockers offer increased strength, as the studs are usually longer than the bolts used to fasten down pedistal mount rockers. Beyond added strength, stud mount rockers are advantagous because they allow adjustments to compensate for changes in the valve train geometry. Stud mount rockers do mandate the use of guideplates and hardened pushrods for proper alignment and durability.
Shaft-Mount: For ultimate rpm potential and durability. Rather than see-sawing on a fulcrum, shaft mount rockers, naturally, carry out their appointed duty swiveling on a solidly mounted shaft.
All info came from How to tune & Modify your 5.0 Liter Mustang
