might have a crack with Steeda pullies (pics)
FR-S8N
1,306
McAllen, tx
Anybody else have this? first one is blurry but the second one is alot more clear.
:notnice:
[/IMG]
good question because i'm not sure. I'm assuming you are asking if that center parts with the crack is a cover, right?
Correct. It looks like a dust cover over the bearing. Sometimes when you slide/tap those on a little crooked, they can crack like that. You can probably get a replacement mailed to you and just slide/tap it on carefully. The bearing is also a sealed unit so I wouldn't think that this is anything to worry about performance wise. :shrug:
I have an '01 GT and mine looks exactly the same. The pulley is not cracked - the hub for the pulley is. And it is not harmful for the engine. It's the hub that thepulley mounts onto on the water pump. I also have the steeda UDP's , and if anything, the pulley is actually keeping the pump hub from further cracking by keeping it compressed.
I was thinking that. If I remember correctly, with my 2001 GT I think it also had that crack. It looked so familiar, but I still took a pic and posted it on here.
