Mini Spools
KJ Hoppus
1,008
Elk Grove CA
"An Auburn mini spool is an economical way to dramatically increase strength in your rear end. By replacing the internal components of your open (non-posi) differential, you effectively lock the axles together for even power distribution to both rear tires. Does not require C-clip eliminators"
what do you think???
Very bad idea for a street driven car. Both tires will spin the same speed hence alot of squeeling while going around corners and alot of excessive tire wear and broken axles.
