Misfire at idle
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
My car has a misfire at idle and i can feel it when im driving around 2k rpms in first gear. The car will vibrate pretty bad when im idleing, but only sometimes. I have cleaned the MAF, new plug wires and plugs, new ECT and new o2's and fuel filter. (They were not all changed because of this problem).
I'm going outside to run a cylinder balance test.
Could this miss be related at all to detonation? My car pings on the highway pretty badly, like above 65. It used to do it from 35 but I put in 93 and 108 octane booster. :notnice:
It doesn't seem like they both could be related, but I hope so.
Thanks guys.
:bang:
Okay, ill look at my balancer.
But I think it's a miss not the balancer thats causing the vibrations because the rpms drop a little it surges.
Today I did a cylinder balance test as well as KOER and the only code I got was
116 or something Coolant Sensor out of range.
This is a new ECT. Could it be bad? I know that coudl cause my detonation, but nothing about the miss. I also passed my cylinder balance test, but thats because the miss is at idle not at 1800 rpms where it tests.
I also pulled out all the plugs, re-gapped them and checked all the wires were down good. And re-cleaned the MAF. Still have a bad idle miss, not sure about detonation.
Check the balancer, just because it's real easy to check, and they go out quite frequently.
FWIW, I would think that a miss caused by bad plugs, wires, low compression, whatever, would be present at any rpm, and not just at idle. But I've been wrong before.
Yeah, me too. It might even be at all rpms, but either I don't notice it or it's not there. But at idle its very noticable and rpms drop and surge.
What I did notice when I was just inspecting the car is that the distributer cap has some play. Like I can tilt it back and forth. It's clamped down on both sides, so I dunno what the deal is.
Where else could the miss come from?
Thanks for the help guys.
Inside the bowl, there are two screws that hold the bowl to the base of the distributor. Check to make sure those are tight. One of mine was loose, and the bowl would rock back and forth, even though the cap was tight, and it was causing some funny issues. Just pop the cap off and make sure those screws are tight.
Yeah I'll check that, though its the top cap that wiggles a little it wouldn't hurt to try.
I kinda looked around for a vaccuum leak and didn't find any. Could that ECT sensor cause it to be lean and detonate?
Oh the way you said it, I thought you meant your whole bowl was loose.
The ECT does effect a/f ratio. For instance, on cold startups, the ECT senses the engine is cold, so the PCM delivers more fuel to help startup. So yea, if the ECT is bad, then it could be causing you to run lean.
Okay I'm going to try a new ECT to try to eliminate the pinging. The detonation is the priority problem.
How bad is it if occassionally the car pings for 5 seconds? How long do I have before I blow some **** up?
I can live with a misfire a little, but everytime my car pings I cringe.
I read somewhere that a misfire at idle is a "lean misfire"
Maybe they are connected! Pinging and misfiring.
I didn't know that a misfire could be cause by a lean condition... I dunnol.
This gasket actually looks like its missing right here.
So somehow my car is running lean causeing both of these problems. The lean misfire and the WOT preignition.
This might sound really stupid but my wires arent like separated. They all run together and probably cross a lot of times. Could this cause a lot of problems? I should go buy those things...to separate them.
You can do the 'spray water on the wires' trick and see if they are bleeding spark.
The EGR gasket is very thing - metal-like. I am not sure you would see it with the EGR bolted up. It takes about 2 mins to unbolt the EGR, so go for it if you want (two nuts/bolts, the feed pipe - soak that in PB first, and a vac line. That is all I recall doing).
I posted more on your other thread.
Good luck.
Do you guys think that the faulty ECT sensor could cause my lean misfire? It could also cause the pinging I guess.
I'll try that tomorrow, just buy a cheapey pep-boys.
