Brakes MM S/S brake hose question
hi all, i have a 5lug brake setup in the front with 2001 GT PBR dual piston brakes calipers... currently the orginial brake hose are rubbing on the tires and are wearing down. I want to upgrade to Stainless Steel brake hose but i want to know if there was a cheaper way to doing this.. LMR has the kit for 90$ but i see Summit Racing has a kit for 50$ SUM-220388(without the fluid bolts) thanks.
What make car are you getting the brake hoses for that they are rubbing?
You can't use fox lines, as they may rub. Unsure if this is your issue but don't want you to see the same issues with new expensive lines.
