MMR 600 long block with Vortech v3?
slayerripkdc
1,341
brewster ny
I am looking into the 5-10 year plan with my little 2v. Just doing some research. What kind of power will stage 3 ported pi's, stage 3 cams and a V3 make on top of a MMR 600? I assume close to 600? Also will spending a little extra money on trickflows be worth it over the stage 3 stockers? All I would have to supply is the stock Valve covers, oil pan and timing cover correct??
slayerripkdc...what heads and cams? How much boost? Auto or stick? If you use the Trickflows you're gonna have more compression than a set of ported heads so that should be taken into consideration. Your hp guess is probably accurate give or take...
