modded 90 with idle surging issues
scld1354
41
I finally got my motor running. (347, 11.5:1, RPM heads, COMP cam grind #FE XE266HR-12, RPM 1 intake.) I cannot get the thing to idle. I have followed numerous "Fixes" listed on the internet, but none have worked. I am trying to run this combo on the stock ECU. Should I get it tuned and hope the tuner can solve this? Am I just waisting my time by trying to fix it myself?
Any information would be greatly appreciated.
Thanks
Jon
Are your injectors and mass air meter matched? What size injectors? I'm running 60's with stock ecu and an SCT chip. My car surges if it's to rich. Do you have access to a wide band afm? I also run an air adjuster on the mass air meter for fine tuning the af at the track. The air adjuster will compensate for 2 sizes of injector. You're right about all the fixes. I can only vouch for mine. Good luck. Mike
