modified long tubes?
64post
45
Sonoma Calif.
I have to ask if anyone with long tube headers has cut off the cone/inverted flare connection to opt for a slip on or in connection from header collector to mid pipe? This seems logical because the inverted cone is reduced to 2.25"outlet from a 3" collector and 2.25 seems to be restrictive in the scheme of things.
So,1: Is it worth the work to eliminate this connection
2: What about the connection at the back of the mid pipe assy.? do the same there where it is reduced?:shrug: Is there much to be gained?
Someone actually makes those....or used to at least. From what I recall, they did a dyno test on it in one of the magazines and it was good for like 10 or 20hp. Mind you, that was on a 400+ horse stroker if I do recall. People done do it cause they have to modify the exhaust instead of just buying simple bolt together kits though.
10-20 HP? that's 1-2 mph off the top. Maybe it is worth while.
