More check engine codes.
95&03GT
24
On my 95 stang I checked the codes here they are.
Car on but not running
this is the 1st code I got and it was only one time
331-But its not in the book.
all these codes below I got them twice
172-heated O2 sensor indicaiets lean condition, right side
176-heated O2 sensor indicaiets lean condition, left side
332-insufficiant EGR valve opening detected
334-EGR valve postition sensor voltage above closed limit
556-Primary fuel pump circuit failure
Motor running
All these code I got twice
116- Coolent temp sensor out of self test range
136-heated O2 sensor indicaiets lean condition, left side
334-EGR Valve postion sensor voltage above closed limit
Can anyone help with what to do about these codes???
