I have a 90 harness trying to convert to EFI and i need to find out where some wires go in my car. So here it goes there are three connectors a green black and grey and the wires i need. on the black connector there is a blue/white wire that goes to the O2 sensor harness it isnt on the autozone diagram either, where does this go. Then there is a black/white one that came from the black connector also, it is the signal return from the clutch switch i think, would i have to install this since i alrady have one in my dash? I also have a white purple one and it goes to the to the 02 sensor harness it is looped to a purple wire on the other side than it comes back through the harness and goes to pin 30 which is the neutral or clutch safety switch, should i have to hook this up? Than i have a Dk green/yellow wire that goes from pin 4 splits, one side goes to the coil connector one goes to the dizzy and one went to the grey plug i cut off the grey plug where did this go have any idea? There is a solid red wire that went to the black plug i know it is a 12v source but i cant find it on the skematic it goes to a "distribution block" of red wires, which goes to the MAF meter pin 37 on the EEC, and through out the harness so is this a crank and run or just crank, or run, Than the red/blue wire that comes from the Dizzy goes to the starting and charging system, is this the battery side of the silenoid. The green yellow one goes to the eec relay coil...is that the same as the Coil for the spark plugs, if it isnt where is the eec relay coil? where would be a good place to splice for the red/blue and red/green one that goes to the dizzy? Will the EEC run with out the Neutral safery switch wires black/white and white/purple hooked up, if not can i just splice into my current Neutral safety switch? There is a blue/white wire that goes to the 02 sensor harness connector then on the actual harness there isnt a wire on that side, what is this, and where does it go?
