  • SVT Tech Forum
More "oomph" with Trac off??
  • Thread starter Thread starter Ganton
  • Start date Start date Feb 21, 2004
Ganton
150
Olympia, Wash. USA
Feb 21, 2004
  • Feb 21, 2004
My '01 snake is stock 'cept for a K&N. Do I detect a little quicker acceleration on dry pavement with the Trac Control off, or is it just the fulfillment of wishful thinking? It's hard for me to remember to push that buttion an switch it off, but when I do, it seems to accelerate a little quicker...
missouri_guy197
1,441
St. Louis, MO
Feb 21, 2004
  • Feb 21, 2004
Most definately...the Traction control modulates both fuel and the rear brakes when the computer senses lack of traction...so with it off it will be a lot quicker...they make plug in modules that can automatically turn it off for you when you turn your car on...I think you can find them on E-bay...
2k1Cobra
37
DFW, TX
Feb 21, 2004
  • Feb 21, 2004
i have a mineral gray 01 too!! anyways, i thought the same thing! I experimented taking off both ways and i actually ran more with the traction control on! everytime it was off i spun everywhere, and that TCS ON just seemed to pull so hard but then i solved that problem with some Nitto's !! now i only cruise with the TCS OFF, and it pulls real hard now!! :worship:
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Feb 22, 2004
  • Feb 22, 2004
Yes, everyone races with traction control set to "off" at the track. It's a must, otherwise you WILL bog (fuel cut, brake engage, etc) due to the traction control. If you have your owner's manual, there is a pretty comprehensive explanation about how it works (ie - it only engages once the system sees "uneven" wheel slip, meaning one side has lost traction, etc ).
Additionally, you can find a "traction control defeat" module over at PEP, www.ponyexpressperformance.com or just deactiviate the traction control everytime you start the car...
Vic_Ferrari
273
lake mary, FL
Feb 22, 2004
  • Feb 22, 2004
I programmed my chip to leave traction 'off' all the time so I don't have to remember to push the button.
As far as I'm concerned, traction control is completely unnecessary on any car.
You should feel it on a GM! By the time it actually kicks in you already have traction again! It also fels like someone is kicking the underside of the car when it kicks in.
Whenever possible, I shut this stuff off..
Modern technology is unfortunately causing a decrease in real "drivers".
Traction control this, torque management that.....make the car partial to understeer instead of oversteer because it more "predictable" (though less controllable).
If I had my way, nothing would have traction control, shift retard or anti-lock brakes.
DirtySanchez
331
Atlanta, GA
Feb 22, 2004
  • Feb 22, 2004
The system is actually passive. It doesn't engage the brakes. As much as my Camaro-driving friends hate Chevy's active system, I don't think that's a bad thing though.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Feb 22, 2004
  • Feb 22, 2004
DirtySanchez said:
...The system is actually passive. It doesn't engage the brakes....
Incorrect. The system does utilize braking. Please see my prior post. Here are pages 111 & 112 from the owner's manual.
SloCobra
25
  • Feb 22, 2004
Traction control is gone on mine. Custom tuning can get rid of it so it will never come on. We did this so the fuel didn't get leaned out under boost and loss of traction.
tfritz
886
SoCal
Feb 22, 2004
  • Feb 22, 2004
That's great! Didn't know they made such a thing. Does it reverse the toggle? ex: pushing the button for the first time will engage instead of disengage?
It's so natural to me to push that damn button everytime I turn the car on, I'm afraid if I get this fix I'll be engaging it instead of the opposite!
DirtySanchez
331
Atlanta, GA
Feb 22, 2004
#10
  • Feb 22, 2004
  • #10
I stand corrected! Or at any rate, I sit corrected.
9
99SVTAddict
613
Clinton Twp, MI
Feb 23, 2004
#11
  • Feb 23, 2004
  • #11
It actually remembers the last setting the switch was at before you shut the car off. So if you turn the traction "off" then shut the car down, the next time you start it up it will still be "off".
It took about 20 minutes to install the module and the wiring instructions were clear enough that a 12 year old could wire this thing up. Plus, they were a top notch company to work with. Highly recommend them.
missouri_guy197
1,441
St. Louis, MO
Feb 23, 2004
#12
  • Feb 23, 2004
  • #12
There's a guy in our club that can make you one of these modules for $40 shipped...here's the info for it:
http://www.stlmustangs.com/forums/index.php?showtopic=10333&hl=traction+control
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
  • JRC99
  • Apr 19, 2025
JRC99
J
J
New 98 Mustang Cobra Owner
  • jtoates72
  • Apr 14, 2023
  • SVT Tech Forum
SVT Tech Forum Apr 19, 2023
Shuttleman83
  • SVT Tech Forum
