Next time you drive look at the handheld (don't run off the road) where it says load. The numbers will vary up a scale from 1-7 depending on where the load is on the throttle. Say if you pull off and you hold the throttle down lightly at a consistent pressure the load my be on 1 when your throttle is about 15% down, if you add more pressure the load will move to 2 say at about 20% down and so on. When the scale reaches 5 its considerade M load.
Your HL would be a mirror of your WOT table settings. You can add timing if you are not pinging. That's the beauty of the PMS is that you can adjust timing and fuel by adding or subtracting in a specific rpm or load setting. You'll get it all in a few days, it took me about a week. Your boost table will not work until you add a 3 bar map sensor.
Pull out your spout and set your timing to 10* and then put the spout back in.
Are you running an aftermarket ignition?
