Well..My tranny acts GREAT in any gear but second..I can normally shift to 2nd when I am up shifting and never have a problem ( every great now and then it won't go). When ever I try and down shift to 2nd I get no grind what soever but it will "pop out" I drained the tranny fluid and removed my shifter and check for any problems..in doing so I did find out someone hand installed a hurst shifter I think ( gold plate ant base had Hurst engraved into it) but I saw no problem so I poured 3 quarts of Penzoil syncromesh into the traynny ..This helped ALL the grind problems I had in a 5 speed Celica that I used to own with the same mileage. I didnt have 5 bucks to buy a fourth bottle for the extra like .6 quarts so I left a small amount of old fluid in the tranny to make up for it. got everything installed and it help a bit but its stll doing it! I have heard people say this fluid is the best for the t45's to help similar problems..if I rev the car and shift to 2nd really fast it helps alot..is there anything I can try to help the problem w/o having to replace the syncros? I don't really have the money for the labor...I heard some ford trannys have adjustable syncros? Any help is greatly appreciated! Thanks!
