- Oct 21, 2006
- 515
- 43
- 49
I have the stock air box with a K&N Panel filter.
I was wondering if this Moroso intake would be any advantage over the stock air box with an K&N?
http://www.moroso.com/catalog/categorydisplay.asp?CatCode=34002
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 3.73 Gears / Eaton H.D. Posi / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / B&M Short Throw Shifter / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Thanks
