Motor is running hot..help
bdazzgt
I had to jerk off the cable to get it to stop.
Dec 27, 2005
328
Springfield MO
I just recently got my ac fixed and i noticed that it runs about 205-210 when it is on, so i went to autozone and bought a 14'' fan to help push air over the radiator when i am crusing down the highway. It doesnt do anything, the shroud is on there and i still am running my clutch fan. What gives :shrug: The car doesnt run hot at all when the ac is off about 195-200* and the electric fan doesnt seem to help. It is a pusher fan just to help air flow. Any ideas are appreaciated ....thanks a lot
lol, not to sound like a dumbass, but do double check your fans direction. and also, you might want to get you're coolant flushed while youre at it. (i used to work at grease monkey) and i remember when i serviced the coolant on my mustang, the temp dropped from 2.5 bars on the temp gauge, to just 2. lol, thank god ford never put numbers on there right.
When on the highway, the fan really doesnt help at all (that's why many OEM e-fans shut off at ~45 mph). And a pusher fan is an impediment to air flow when at speed.
You're noting that temps go up 5-10* with the AC on - that's about right for most cooling systems. The heat from the condenser is sent through your radiator, hence running a little hotter.
Good luck.
Good luck.
Very true..seen it many times on various models...wouldn't give it a second thought.
What happens is when it gets to 205-210ish it spews out antifreeze. So the fan is actually hurting airflow going down the interstate, i never thought of that. The fan is blowing in the right direction, so what would cause this to spew out antifreeze?
Where are you spewing antifreeze? Out the overflow?
THat is the kind of info one wants to put in an opening post.
Good luck.
Yea sorry i didnt specify where it is coming from, yea it is coming out of the overflow hose. I have a 192* thermostat in there, the fan clutch is new so i know that isnt bad, i have had one lock up on me before and it wasnt pretty. Anyways what would you recommend i do? Should i change the T-stat to a 180*? The car doesnt have an air dam does those help a lot? It wasnt on there when i bought it and i just never put one on, any suggestions are great...
We still need more info on exactly what is happening with what you referred to as spewing.
A system under 16 PSI with a 50/50 mix of water to coolant will not boil till around 255*F.
If you simple have bubbling water flying from the radiator and into the overflow bottle, I'd check/replace the cap. We simply need more info.
The little air dam under the car does help when you are driving at speed (40 mph+). A lot of folks say in milder climates they dont miss it. In hotter ones (up near 100*F), people notice a difference. I did (I had to get a new one for the 94 and did a custom set-up on the fox).
Good luck.
spewing- i mean it is coming out of the radiator hose by the cap and going into the overflow bottle. I will buy a new cap and see what that does, do you have any recommendations? It has been 90*+ the last three days so i will get a airdam will a stock one work? Thanks for all the help hissin.
The new cap sounds like a plan. No recommendations on the cap - I havent found any great ones (like I have for t-stats). A parts store unit should work and it's easy to swap in if you get a bad one (I have before).
Even if the cap is not the issue, it's a maintenance item anyhow. It does sound likely though.
A stock air dam should work like a charm for you (it did for me - I did the new one for aesthetics).
Good luck.
bdazzgt said:
Would i benefit from switching from my 192* thermostat to a 180* Mr gasket not a cheap autoparts store one? That would make me feel better if it didnt run so close to 200*
That's exactly what I use - I love those stats.
I swapped from a brand new parts store 180* stat to a Mr G 180* and my idle temps dropped about 8*F. I attribute it to the Mr G opening when it's supposed to (which is pretty critical with electric fans and controllers, for one) and they flow better than the cheaper stats. Well worth the extra couple bucks.
I have an OEM stat in there, it isnt a cheap parts store replacement it opens fine i can watch the gauge drop a few degrees around 195 ish when it is supposed to open, it just runs ab out 4* warmer then the t stat until i turn the air on, well i will order one of those t-stats this weekend and we will see what happens also i will get an airdam and a new shroud since mine is cracked in multiple places. Thanks Hissin
