Motor Mount Bolts
JD1964
there is enough sticking out to grab on to
3,427
1,519
194
Maryland
What size are the bolts that hold the motor mount to the engine block on the 5.0 engines? I need to get the correct size washers to shim the motor up just a tad.
I realize it's easy to check myself but I got the idea now and I'm out and not with the car. Wanna get washers when I'm out.
Are they 1/2" or 3/8"?
Follow up. I used 7/16 flat washers. 3 at each mount to engine block location. It raised the engine about 1/4". Just enough to bring the fan closer to the center of the shroud and avoid contact at the bottom.
