Motor mounts gone crazy
  • Thread starter Thread starter 67OLDBLUE
  • Start date Start date Nov 13, 2005
67OLDBLUE
Bristol, FL
Nov 13, 2005
  • Nov 13, 2005
Hey, new here. Just dropped my new 302 in my 67 coupe. Secured the right mount with no problem, but the left side mount is like over an inch from the hole for the bolt? Using the tall mounts like the ones on the old 289. Can't remember this problem years ago when I rebuilt the 289. Thanks for any help.
Shakin66
628
Waycross, Ga / Lake James, NC
Nov 13, 2005
  • Nov 13, 2005
Have these same mounts been in the car before? If so you are just not lined up correctly. I had my engine/trans in and out of my car taking measurments 5 times in a couple of weeks and when I was ready to install it for good I had the same exact proble and ended up pulling it back up and the next time it went in great. Good luck!
iskwezm
4,159
20
79
Rowland Heights,California
Nov 13, 2005
  • Nov 13, 2005
happened to me to with new mounts from Kragen,they fit like ass
67OLDBLUE
Bristol, FL
Nov 13, 2005
  • Nov 13, 2005
Same mounts. Still have chain on engine. Pulled it up and down several times. Still not lining up? Guess I'm going to try to bend some metal and rubber.
latamud
791
Tampa, FL
Nov 13, 2005
  • Nov 13, 2005
Remove the mounts from the block. Place them where they go wit the through bolt loose so there is some play. Then lower the block down and line up the holes from underneath, run the 4 bolts into the mounts and block by hand. Tighten all 4 up then the through bolts. Be creful when under the car. I try not to get under the engine.
67OLDBLUE
Bristol, FL
Nov 13, 2005
  • Nov 13, 2005
Thanks for info. Will try in a.m.. These small things are allways the pain in rear and holds things up.
brianj5600
1,964
Middle TN
Nov 13, 2005
  • Nov 13, 2005
'67 motor mounts and frame mounts are unique. I had problems with mine too. The frame is drilled different, the frame mounts are different and the uppers are different. http://www.fomoco.com/forummain/res...Option=0&Name=on&Email=on&Key=67 motor mounts
65fastback2+2
1,229
Louisville, KY
Nov 13, 2005
  • Nov 13, 2005
you can make em work....i did in mine, just make sure and drill through em and put a nice big bolt through em, or you will tear them to pieces in 2 weeks.
rbohm
6,698
550
204
tucson,az
Nov 13, 2005
  • Nov 13, 2005
what brian said. check with a mustang parts supplier and get the right mount for the 67. making the other mount work can be done, but it is not the right way to do it.
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
'67-68 Scott Drake Trap Door w/6x9 Speaker Pods
  • bchampion
  • Jun 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 16, 2025
bchampion
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
E
Parts for my Holley BBF fuel pump PN 12-460-2 repair kit 12-871
  • Engineer Duane
  • May 4, 2025
  • Other Auto Tech
Other Auto Tech May 5, 2025
