I have a '65 coupe that will have a 347 stroker rated at 425hp. I will be running a Tremec TKO transmission.
I have read many threads where people had to modify the transmission tunnel to get the tranny to fit. Many other people claim that no modification was needed to get theirs to fit.
I don't want to modify the transmission tunnel but would like to get as close as possible to the proper driveshaft angle. I recall reading a thread where someone mentioned that the TCP motor mounts actually lower the engine a few inches which allows for a more accurate driveshaft angle.
Is there any truth that the TCP motor mounts do lower the engine a bit? Do you guys recommend a set of aftermarket motor mounts such as these over the stock ones?
I am not a big gear head so I appreciate all of your insight and help!
Chris
Chris
