Motor Mounts
  • Thread starter Thread starter Fri Guy
  • Start date Start date Mar 31, 2022
  • 3
First Prev 3 of 3
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Apr 10, 2022
#41
  • Apr 10, 2022
  • #41
Why don't these fit 79-83 ?
M
Monkeybutt2000
Mustang Master
Aug 11, 2019
1,387
851
133
Lafayette,IN
Apr 10, 2022
#42
  • Apr 10, 2022
  • #42
K-member is different. Solids FTW.
limp
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Apr 10, 2022
#43
  • Apr 10, 2022
  • #43
What is different about it? So that leaves me with no options on my 83? I was going to use the originals, they look fine, but I hate to have to change them on the car if they break...
General karthief
Mod Dude
Aug 25, 2016
28,143
10,763
213
polk county florida
Apr 10, 2022
#44
  • Apr 10, 2022
  • #44
I can get with you and let you compare a mount for the 86-93 to the 83 you have, I don't know what would be different between the years.
pm me your phone #
Reactions: limp
limp
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Apr 11, 2022
#45
  • Apr 11, 2022
  • #45
Soo, how come the "stock replacements" from foxresto and CJpony fit 83-93?
General karthief
Mod Dude
Aug 25, 2016
28,143
10,763
213
polk county florida
Apr 11, 2022
#46
  • Apr 11, 2022
  • #46
I believe they will, the difference I found searching around was the early mounts have a replaceable 'biscuit ' that bolts between the two metal mount brackets, the later mounts are molded to the lower mount and the upper is bolted to the upper and have a 'safety ' rubber molded bolt that keeps the two metal mounts from separating.
Now I didn't find much on vert mounts but I will have a chance to compare a replacement vert mount to an original soon.
Reactions: 7991LXnSHO
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Apr 11, 2022
#47
  • Apr 11, 2022
  • #47
There ya go. Some slight modifications required.
Reactions: limp and 7991LXnSHO
limp
5 Year Member
Oct 4, 2020
5,520
2,947
173
Florida
Apr 11, 2022
#48
  • Apr 11, 2022
  • #48
Thank you for the information.... What product is this note with?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Apr 12, 2022
#49
  • Apr 12, 2022
  • #49
It's in the fitment notes tab on engine mounts on LMR's site.
Mustang Heavy Duty Motor Mount Kit (84-95) 5.0 - LMR
Upgrade your motor mounts to the more desirable 1984-1995 Mustang heavy duty mounts for better support with this Heavy Duty Motor Mount Kit!
lmr.com
https://lmr.com/item/LRS-6038PR/1984-95-Mustang-50L-58L-Urethane-Motor-Mounts
https://lmr.com/item/PT-6501BL/1983-95-Mustang-50L-Urethane-Motor-Mounts
Reactions: limp
F
Fri Guy
435
259
83
May 4, 2022
#50
  • May 4, 2022
  • #50
How much will the energy suspension mounts lower the engine compared to the prothane mounts? Need to make sure I won't have any clearance issues with the other stuff on the car. Is there a difference in height between the prothane and energy suspension transmission mounts or is it just the engine mounts?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
May 4, 2022
#51
  • May 4, 2022
  • #51
The ES mounts are modeled on the convertible mounts while the prothane mounts are the early hardtop mounts. The convertible mounts are 1/2" lower than the early hardtop mounts. I assume this carries over with the poly versions but it's really an unknown how this plays out with real world measurements.
Reactions: Fri Guy
F
Fri Guy
435
259
83
May 4, 2022
#52
  • May 4, 2022
  • #52
So the prothane mounts should be the same as the stock mounts on a 90 GT as far as height? Not sure what years are covered under the early hardtops.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
May 4, 2022
#53
  • May 4, 2022
  • #53
I believe pre-91 is considered the "early" hardtop mounts. 91-93 all got the convertible mounts that were used from 87-90. I don't know the pre-87 years
F
Fri Guy
435
259
83
May 4, 2022
#54
  • May 4, 2022
  • #54
Hmmm. So if my stock ones were replaced with the prothane ones wouldn't the engine have stayed at the same height?
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
May 4, 2022
#55
  • May 4, 2022
  • #55
In theory it should have, but stock mounts can be worn and sag, and the poly mounts can be firmer than stock not allowing the motor to "settle" as much.
F
Fri Guy
435
259
83
May 4, 2022
#56
  • May 4, 2022
  • #56
My engine definitely sits higher than stock so not sure what is going on. Can the mounts be replaced while the car is on the ground and without a engine hoist to lift up the engine? Maybe a floor jack under the balancer with a piece of wood or any other ways of raising the engine enough to replace the mounts? I'm debating on the mounts vs a 2" steel cowl hood.
  • 3
First Prev 3 of 3
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
E
3.8l upgrade, motor mount options
  • Ed Russell
  • Nov 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 2, 2025
Ed Russell
E
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
