Mounting Taurus fan
Hey guys...I've got a griffin 3-core rad in my car and I nabbed a Taurus fan from the junkyard. Cleaned it up etc and it seems to be in decent shape. Gave it a real quick mock up etc and it seems to clear my engine (windsor), so that's good, but I'm curious how some of you guys go about mounting this fan to your aluminum rads.
Thanks for the help guys :hail2:
Those radiator pull through zip ties, and make sure to use the foam pads they include, or fabricate some small aluminum brackets and bend them around to mount on the fan on one end, then the other end to where the rad bolts to the rad support.
well I assume you have the mechanical fan off already?
If so cut a piece of cardboard to protect your radiator. Then slide the fan down and see how the clearance is.
Im running a 2 core radiator and its pretty tight. But I could gain ~1/2" by going with countersunk bolts on the W/P pulley. So you might need to do a little trimming on the fan shroud.
The pull through radiator straps work great. And at the top you can use a small bolt and clip to attach it to the top of the radiator.
few early pics of mine.
I mocked mine up using aluminum straps cut at 1" width..ends folded over rad edges and screws into the shroud to secure it. I used electrical tape around any of the strap edges that contacted the rad directly....no vibration and quite secure.
