Mr Freeze..Anyone Heard of This?
don't have any good info for you on it, but I'm pretty sure it was covered in one of the big mag's a few months ago. I was a bit disappointed because it wouldn't work with Kenne Bells for some reason. I'm thinkin about one of those snow kits soon also. Friend of mine has one in the garage, ordered it from kuwait, puttin it on when he gets back, let ya know how it goes, good luck
I have heard from Anderson that it works really well and their dyno tests prove it. I know for a fact that AFM doesn't BS or fluff any of their products. I just wish they would change their colors. Im not a fan of the purple and yellow..barf.
<-- Thinks buying the "Kits" is a big waste of money water/meth injection works. Just dont waste your money on a kit you can get all the parts they sell you for much cheaper and put together your own kit. Just my 2 cents.
I should really shut my mouth and start making these kits because people seem willing to pay way to much for them.
I found the mag it was in and read the article.
BIG PROBLEM: It only works on the INLET tube to the Vortech...I dont know if I want washer fluid spraying into my Vortech.
The Snow kit works in the tube b/t the blower and TB. You can get the $299 model which uses the boost, or you can get the $399 one which is controlled by MAF voltage :nice:
Shaun..in the mag article, they located in the empy battery slot, and painted the bottle solid yellow to match the car it was put in...IM sure if you used it, you could paint it black.
Labora: If you get the kit made soon, let us know.
RC
A friend of mine has the Mr. Freeze on his 92 GT with a Vortech T-Trim pushing 18 psi. With that kit, he is able to safely run that much boost and on his 347 stroker with the T-trim and Mr. Freeze, he turned 680 to the rear wheels (sorry, I don't know a before # to compare to without the Mr. Freeze, but I think he always has to run it on his car to avoid detonation, so I don't think he did a dyno run without it.) Anderson's kit as you said uses windshield washer fluid that contains methanol, and from what they described to the friend of mine, it is safe because the supercharger atomizes the fluid before spraying it into the intake, therefore it is not really a liquid, but a chilled gas. I think they are worth the money for sure, and it won't cost you an arm and a leg to refill!
1. If you have a TwEECer you can run a different setting if you run out...with a PMS, you can program it to do the same.
2. Yes, the Vortech atomizes it, but My concern is the fluid going into the Vortech itself.
Thanks for the post.
RC
YEAHLOH95 said:
a friend of mine just went from 575 to 612 with a metanol inj, i say those number seem to make it worth while :banana:
It is worth while, but which one does he have? I know the Mr Freeze is under $200 but to spray it INTO the blower :nonono:
Both Snow kits spray after, but the $299 stage 1 is on boost only....while the $399 stage 2 works off MAF voltage :nice:
See if you can find out.
RC
94GTLaserRC said:
Labora: If you get the kit made soon, let us know.RC
As I said I SHOULD start making them. Listen guys don't waste your money! I had a good friend make kits for Neon SRT's for a period of time and what goes into them isn't much and can easily be fabbed together for less then 75-150$ tops!!
Also to add some tech to this post. The biggest concern of where to have the nozzle is how well it can atomize. If it doesn't break down into a fine mist it can cause the leading edge of the fins (be it turbo, blower etc) to rust and break down over time. Also meth\alcohol is not good for certain kind of blower blades. (It depends on the type of coating they have on them some types of teflon I believe? do not favor this.)
Also for the guy who was asking about doing it on a N/A mostly stock car. I’ve heard people claim they get better gas mileage with the water injection how true that is, is well debatable. Now undebatable is how clean it makes the intake, heads, combustion chamber. The CC on my friend’s car where very clean very little Carbon build up!
I’ll be doing water injection on a grassroots project of mine soonish. I will use a windshield wiper bottle, extra windshield wiper pump (maybe a extra fuel pump I have and a extra injector if I feel like trying it out.), on/off switch, and a fine mist nozzle. Pretty simple. It’s on a race car so not much need for it to be on/off during normal driving.(turn it on while racing off while in pits) If you want to get more elaborate it isn’t hard to add a pressure activated switch so the spray comes on at Xpsi. This is how my friend did the SRT kits. Of course from what I’ve seen most people don’t want to take the time to do it themselves and are happy to pay big bucks for this kind of thing!
<-- Just trying to save some stangers some money..
