MSD 72lb injectors
  • Thread starter Thread starter onehotpony
  • Start date Start date Dec 17, 2007
onehotpony
29
coral springs, fl
Dec 17, 2007
  • Dec 17, 2007
i purchaced a set of msd injectors 72lb....they are a universal fit but will they fit my holley systemax intake, and aero rails...i will be purchacinga low impedence driver from anderson to compliment my pms
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 17, 2007
  • Dec 17, 2007
wouldn't see why not
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 17, 2007
  • Dec 17, 2007
Holy hell those are big injectors. How much boost you planning?
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 17, 2007
  • Dec 17, 2007
they're low impedance!
onehotpony
29
coral springs, fl
Dec 18, 2007
  • Dec 18, 2007
i know they are low impedence, thats not the problem, i was wondering if i would hav a problem fitting them into the manifold.... the guy at msd said they are universal, but resemble a delco injector, similar to a gm... going to be running about 14lb now but going to up grade my blower to a ysi trim 18lb probally...... just bought a iron eagle boss block and scat forged rotating assembally ross pistons..331..custom grind cam.... magnafuel fuelsys. 575 series pump.... want to make 700+ hp
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 18, 2007
  • Dec 18, 2007
was directing that to 95 stang there above me
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 19, 2007
  • Dec 19, 2007
So is it a Dart Iron Eagle or an FRPP Boss block? Two different parts there.....
If the injectors are "universal," then they most likely are dimensionally similar to the standard Bosch design that Ford has used for the last 25+ years for port injection. The O-rings are 14mm OD. When measured from the outer edges of the o-rings, the distance should be about 2 11/16". Total overall injector length is right about 3".
When in doubt, check the dimensions supplied by MSD against your present injectors.
http://www.msdfuelinjection.com/efi_injectors.html
onehotpony
29
coral springs, fl
Dec 19, 2007
  • Dec 19, 2007
sorry didnt mean to put boss in there... its a sportsman iron eagle. ok i will check that out.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
