- Sep 22, 2004
- 506
- 0
- 0
Ok msd sent me these diagrams to wire up the rpm switch and retard control to my 6al and n20 soloniods...now instead of the wire goin to the sol. i hooked that up to a headlight bulb...so i could make sure it works right b4 i blow my car up...anywayz instead of the wire removing ground to the sol...its removing power...??.....and on the window switch...the on rpm is really the off point and vis versa...which wire could be backwards??...i tried to remove the relay from the whole thing and it didnt make a difference...what would the relay b there for then?
