MT streets questions
  • Thread starter Thread starter GetUsumFox
  • Start date Start date Dec 13, 2007
G
GetUsumFox
NC
Dec 13, 2007
  • Dec 13, 2007
i have a question about some slicks, im running a set of street tires on my 89' hatchback car, im running a 306 with a little over 350 hp and about the same torque. i have a "z" spec transmission that can withstand almost 400 hp,
i want some slicks, what kind, and size should i run??????????????
NKau
1,346
Jefferson, WI
Dec 14, 2007
  • Dec 14, 2007
I've had good luck with both MT ET streets, and the BFG Comp TA DR's
Blown331LX
227
Chapel Hill, NC
Dec 14, 2007
  • Dec 14, 2007
What do you want the tire to do? What gear do you have? Auto or manual?
Flavadave4
1,044
21
49
Utica, NY
Dec 15, 2007
  • Dec 15, 2007
ET streets are a great tire......
Size will depend on what gear ratio you have in the rear end and what you can fit in the wheel wells. 275's are a common width found on cars with stock wheel wells and control arm/quad shock suspension. If you have a more custom set up back there you'll have more options.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
