I have in stock, Urethane rebuild kits for the 74-78 Mustang V8 Motor mounts. If your mounts are seperated,or just falling apart you already know how hard it is to find replacement mounts, and how expensive it is to but any kind of used mounts.
These kits use the steel parts of your exsisting mounts,and replace the worn or deteriorated ruber with new urethane. The replacement urethane has been measure to have the correct hardness as the original rubber. You get everything you need to rebuild 1 pair of mounts,including detailed instructions,and basic hand tools is all that is required to do the job.
If you are looking to do a V8 engine swap into your II I can also provide you with a complete rebuilt pair of mounts. This is a original set of MII V8 mounts already rebuilt with my urethane kits. These are in limited supply.
If you are interested email me at [email protected]
