rd said:I actually bought the spring from a salvage yard during a random trip with my brother in law
who the hell buys springs, bolts, nuts, or anything pocketsized like that from a junkyard? nevermind, maybe im just a clepto
Bad92GT said:BIGGEST MYTH EVER..
the K member.. is a black hole for your tools.. and bolts.. its magnetized and attracts your very expensive snap on ratchet and that hard to find bolt specially made to that part.. and eats it.. i've lost so many parts in that damn thing..
FarBeyondDriven said:Mustang myth #485940a
Modding a mustang is cheap
Strype said:That's how they sold the cars so cheap back then. Almost anyone could afford a mustang back then.
I agree about the header bar. My first 2 mustangs were verts. And the t-5 was a joke.
Air silencer? S T U P I D idea.
MyBad70's just went out along with his battery yesterday because he like many of us is running an electric fan![]()
KCoppola said:my ashtray door works fine AND so does my map light.
In the case of my car when it was stock, no they arent lol The myth of the needing 24 lb inj to make 300 rwhp, is a sketchy thing at best. Yes you can get to 300 rwhp with 19 lbers but they are more then likely operating at full duty cycle and need to be upgraded with even a slight bump in power. 24 lbers on a car that doesnt have a h/c/i is ridiculous though and more then likely will make the car run like crap. A myth that I have to contribute is the notion that all exhaust installs are a simple 1 2 3 install. Yeah theoretically, they arent complex but everyone i have ever done in order to get the damn system to fit right has been a pain in the ass.jinx369 said:Wait.... stock 5.0's aint fast ?!?!?!![]()
Mustang5L5 said:That means 99% of owners don't care if their car sounds like the world is coming to an end and they gained 2.4HP in the process.
Boss 351 said:In theory the 19# injectors are good up to 245hp at 100% duty cycle. My car runs out of fuel at around 4500rpm, I can hear it ping and the engine starts to stutter, I have stock fuel pump and injectors and I think I'm at the 240hp range according to my MPH and weight...
S&B said:myth 715
Owning a mustang doesn't necessarily mean you drive it all that much.
Aliate X said:I have my 19lbs on TFS h/c/i with a 255lph pump and AFPR, I bounce it off the rev limiter sometimes in first (burning out), never ran into a fuel cut.
Boss 351 said:I still have the stock ORIGINAL pump, it doesn't help much lol But I'm going with 24# injectors and a calibrated MAF for my '69 heads since I hope for at least 280hp flywheel HP. I'm even going with flow balanced injectors since my goal is as close to perfect combustion in each cylinder for the most HP with less partsSince you know we only have 2 oxygen sensors so the computer will only play with each bank (4 injectors) to fix the A/F ratio (so you can still end up with lean or rich cylinders), if all the injectors are working at the same flow rates, it will be easier to maintain a more consistant combustion.
