Mustang5l5's Progress Thread - Archived Progress thread '08-'20.
So I modeled up a trigger wheel. Still need to refine the inside details as I need to figure out how to mount it on a stock style harmonic balancer and to allow for it to be orientated correctly
The 36-1 wheel actually has 35 teeth correct? The 36th tooth is deleted? The keyway in the crank is at TDC or 180 out when it's pointed straight up correct?
Need to get s junk balancer to design up the mounting. Anyone have a totally junk, worthless stock balancer they can send me?
I have access to a laser cutter, so I'd rather design up my own trigger wheel vs trying to adapt a universal.
I am so jealous that you have access to a laser cutter.
This would have made the instrument cluster for the LCD screen easier and the still need to build paddle shifter mount for the steering wheel too.
Another pic of innovator's west setup for my own personal reference down the road.
I could just machine 1/8" off the pulley mounting face, and then sandwich the 36-1 wheel between the balancer and pulley. Hmm...things to think about here.
But if anyone has a junk balancer that's really only good for scrap they wouldn't mind giving to me, I'd appreciate it. It's amazing that people are trying to sell balancers with the rubber clearly falling out for $30 plus shipping on ebay.
I should probably just purchase the balancer I am going to run, and then tailor the wheel to fit it based of it's measurements. Still need to figure out orientation so I can cut the bolt holes into the wheel in the right spot to point the missing tooth where it needs to be.
Some more reading to do. no balancer in hand, so trigger wheel will be on hold for now. Not like the engine is out of the car yet....
Don't fret too much on the missing tooth orientation, so long as it's behind (countercloskwise) the pickup at TDC. From there, you add an offset value into MS to make it read exact.
Reactions: Mustang5L5
So more work on the intake today. Some careful bending of the vac ports and I got this to fit well
Next up. Punch that tap out. Mangled the hole a bit, so I just drilled/tap for next larger size. Done
Here's my vac layout. Pretty much same as stock. Ignore the chrome vac tree. Spare part I had and used as filler due to painting the one I will use.
Speaking of paint. A few test sprays. Still a bit more sanding and cleaning to do, but wanted to test the color. Looks oem to me
So ill probably have to 'T' off of my big port?
Looking good! Heres my totally "rare" intake that I be messing with.ATTACH=full]597819[/ATTACH]
On my intake, it looks like I need to run a hose from the big vacuum port to the PCV, and cap off the coolant ports. I should be able to use the longer, skinnier ports for the brake booster, FPR and cruise and cap off whatever lines are left? Looks like that's the only way mine intake will work. What are you thoughts? Your advice would be appreciated. Sorry about the previous comment , didn’t mean to put it there.
