mustangben1990
  • Thread starter Thread starter mustangben1990
  • Start date Start date Sep 7, 2007
M
mustangben1990
windsor
Sep 7, 2007
  • Sep 7, 2007
HI ALL
I HAVE A MUSTANG 1990 LX COUPE
I JUST DID SOME ENGINE WORK
THE BOTTOM END IS STOCK
I DID NOT REPLACE THE PISTONS OR CRANK
I JUST DID THE TOP END
I REPLACED THE CAM TO A E303 ,HEADS(GT40 TURBO SWIRL), UPPER AND LOWER INTAKE (TRICK FLOW,TRACK HEAT) ,INJECTORS (24 LBS) ,THROTTLE BODY AND EGR
70MM ON BOTH ,MASS AIR METER (C&L 24 LBS) ,FULL MAC EXHAUST
BUT WHEN I GO TO START THE CAR IT WILL NOT STAY STARTED
I PUT THE TIMING AT 10 DEGREE TO BE ON THE SAFE SIDE FOR NOW
BUT IT WILL NOT STAY STARTED UNLESS I GIVE IT THE GAS
DO I NEED A FUEL PRESSURE REGULATER TO GIVE IT MORE GAS ?
I NEED SOME HELP PLEASE
408gt91
114
N.H.
Sep 7, 2007
  • Sep 7, 2007
double check your timing and make sure your pcv is in the intake.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 7, 2007
  • Sep 7, 2007
mustangben1990 said:
HI ALL
stock regulator on the car ? floor the gas to get it started , that will shut the injectors off , keep patting the gas till it warms up a bit and see if it will run then , you might need to adjust your TB set screw for your idle if its a new TB ...., chances are the C&L meter although calibrated for the 24s / is not pulling enough fuel at start up , putting an adjustable regulator on it and get it running and pull about 2lbs of fuel pressure might help if adjusting the set screw on the TB doesnt fix it , if all else fails , put the stock 19 lbs back in and stock MAF until you can get the car tuned with a chip....with those engine mods the 19s will be enough to hold you over ......
M
mustangben1990
windsor
Sep 7, 2007
  • Sep 7, 2007
YES IT IS A STOCK FUEL REGULATOR
SORRY A TB?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 7, 2007
  • Sep 7, 2007
SORRY A TB?
throttle body
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 7, 2007
  • Sep 7, 2007
TB= Throttle Body. And turn caps lock off please.
M
mustangben1990
windsor
Sep 7, 2007
  • Sep 7, 2007
OK GREAT THE CAR IS STAYING ON NOW
BUT ITS RUNNING A LITTLE ROUGH SO I PLAYING WITH THE TIMING A BIT
14 DEGREE SEEMS TO WORK BUT STILL ROUGH
ANY MORE SUGGESTIONS
AND THANKS FOR THE HELP SO FAR
M
mustangben1990
windsor
Sep 7, 2007
  • Sep 7, 2007
AND I SEE SOME SMOKE COME OUT OF THE PIPES
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
