my 351 build
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
yo, ok so Im gonna build me a 351w finally, Ive said im gonna do it for years, but it never happend!!! ok so Im gonna buy a stock 351w roller block from a f250, use the stock rods and crank, then put a good set of pistons and rings. it will get some, well at the very least a set or warmed over gt40's, 30lberz, and a big intake, and exhaust, prolly a 75mm tb or a 80mm tb, I would like around 300hp to the ground, and about 450 or more with some gas.
sounds good? ill have pics next week......
351 Build...
Great... befor you start on the rotating assy. Look into the 393 stroker set up!! There are a lot of powerfull 393s out there, and they are pretty inexpensive to build!! Keep the 351W rods, add ARP Bolts. New Crankshaft, 302 W ( 5.0 ) forged pistons.. and your there!! Have the GT40's worked ( ported/ performance Valve job) and you can have over 350-365 at the wheels ( with mild build)!! and then do your spray.... your flying!! Just a thought......
Just me..............................
Thumper
