ite guys the time has begun to start on the 4v, actually im just too lazy to work on it.. so here be the specs!!
ported mach intake
acufab tb
intake spacer 1"
worked c heads/ported and milled/ coolant mod
the 99-01 cobra cams
stock rotating assembly/ gt crank/plasma moly rings
good oil pump/windage tray
should be around 10-6 to1 comp after its all over
and later ill add the L maf and long tubes and jlt pipe
how much you guys think she'll make? im thinking revving it to 6700-6800 as a shift point.. i would like to go 110mph n/a thats my goal this year with this engine..
ported mach intake
acufab tb
intake spacer 1"
