My 89 5.0 Very Build
  • Thread starter Thread starter jdemolet
  • Start date Start date Mar 1, 2015
  • 3
First Prev 2 of 3 Next Last
J
jdemolet
139
#21
  • Oct 3, 2015
  • #21
well the e7 heads are free I have the bits to do the port work. I have a local u pull it for gt40 heads for 100 bucks but every time I have been they are either cracked real bad or already taken off. my local machine shop would charge 550 for a complete redo new springs valve job checking for straightness and cleaning. e7 heads ported with my gt40 ported intake and a decent cam is my new goal
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 3, 2015
#22
  • Oct 3, 2015
  • #22
You are crazy to spend that much for E7's and will be very dissapointed when they make 20hp. Save up and get a set of TW or AFR heads.
Your money, your car.
Reactions: A5literMan
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Oct 3, 2015
#23
  • Oct 3, 2015
  • #23
Here I go assuming but I think he's saying the GT40's would be about $100 PLUS $550 to clean them up and get them ready for install. The E7's are free and he will do the porting. Carry on.
It's Saturday and it's time to carry on with some
J
jdemolet
139
#24
  • Oct 3, 2015
  • #24
Yeah e7 heads are free I will do the porting compared to 100 for gt40 then 550 to clean them up
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Oct 3, 2015
#25
  • Oct 3, 2015
  • #25
650 total vs self ported e7....
The gt40 unported will still out flow the ported e7, unless you really know what your doing.
If it were me I would save up and buy the tw heads.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Oct 3, 2015
#26
  • Oct 3, 2015
  • #26
Agreed. Buy some used trick flows. Just port matching/cleaning up stock heads isn't going to do it(maybe 20hp). If you're going full tilt and really know what you're doing and buying quality valvetrain you're still into the price range of some used heads(or more). Heck wait until thanksgiving time frame and summit usually has the new ones on sale. I did last year and saved over 250$(including rockers which were basically free after discount)
J
jdemolet
139
#27
  • Oct 4, 2015
  • #27
im doing the old school hot rod tricks. im going to throw 7 psi of boost to it
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 4, 2015
#28
  • Oct 4, 2015
  • #28
Like I said..... $250 for a set of gt40's with rockers.
gt40p heads|GT40|mustang
J
jdemolet
139
#29
  • Dec 28, 2015
  • #29
since the holidays are done now time for an update. purchased a different block and got all forged internals also got gt40p heads with trick flow springs. also got a pro m velocity 95mm maf from an 03 cobra for 60lb injectors the motor is ready to go back together and be swapped out and ready for tuning
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Dec 28, 2015
#30
  • Dec 28, 2015
  • #30
I'm not trying to be negative. Just trying to inform. Forged internals are nearly useless in a stock block. The block will crack well before even a stock cast crank will break. Now if the goal is to eventually put that assembly into an aftermarket block...just be careful with any poweradder beforehand. I hope you're adding some forced induction to those inj/MAF combo. If you plan on running it n/a you're going to have issues. What is the build plan? Intended use of car?
Reactions: mikestang63
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Dec 28, 2015
#31
  • Dec 28, 2015
  • #31
Agreed....
I have heavily ported gt40s, cam, headers blah blah blah, 8.5psi positive displacement supercharged. 47lb injectors. At redline in full boost I am using 52% duty cycle.... can't imagine trying to tune the idle with 60lbers....
2000xp8
Aug 8, 2003
8,029
1,619
194
NJ
Dec 28, 2015
#32
  • Dec 28, 2015
  • #32
In your first post you say this is your daily driver.
I'd seriously suggest you take these guys advice and back the injectors off.
Honestly, i'd probably just run the stock injectors with the stock meter or a 75 pro m for 19's.
At best a 75mm pro m and 24's.
60's and a cobra meter will be making an expensive mess out of something very simple.
J
jdemolet
139
#33
  • Dec 28, 2015
  • #33
I got the maf for free and im going 24lb injectors its a used aftermarket ford racing block
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Dec 28, 2015
#34
  • Dec 28, 2015
  • #34
Who is tuning the car? That maf will need a pigtail spliced into your harness and the car won't run until it is tuned. The maf transfer function is in the ecu, not the maf. Soooo who is doing the tuning?
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Dec 28, 2015
#35
  • Dec 28, 2015
  • #35
Hmm now you have me wondering... what ecu are you running? I can give you advice based on that rather than guessing. Tuning in a lmaf or cobra maf is difficult as it requires complete rewrite of the maf function, most tuners will get frustrated and get it "close". a good tuner 100$ an hour. Food for thought.
2000xp8
Aug 8, 2003
8,029
1,619
194
NJ
Dec 28, 2015
#36
  • Dec 28, 2015
  • #36
Sell the cobra meter and buy a 75mm pro m bullet. In 30 minutes your car will be up and running for free.
If it's really an 03 cobra pro m (which I didn't even know existed), you may even make money.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Dec 28, 2015
#37
  • Dec 28, 2015
  • #37
wait- you have a ford racing aftermarket block? R302? If so, those gt40P heads are a major choke point. I wouldn't be putting cast iron p heads on a built aftermarket short block.
What cam? What are the specs on the block, internals?
Also as others have said, the MAF and injectors are wrong for your setup. You said you have 60 lb injectors but then said 24lb? 24lb are not enough and 60 are way too much. Who is picking out these parts for you?
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
Dec 29, 2015
#38
  • Dec 29, 2015
  • #38
... pm me if you want parts for this setup...
If you have an A9L ecu.
TOOLOW91
20+ Year Stangneter
8,687
234
S.I.NY
Dec 29, 2015
#39
  • Dec 29, 2015
  • #39
This is spiraling out of control real quick LOL . Feel like i am watching myself. Why not post a detailed current parts list so we can help out and maybe pitch in some suggestions.
Reactions: A5literMan and FoxMustangLvr
MY 85 GT
1,852
208
104
New Jersey
Dec 29, 2015
#40
  • Dec 29, 2015
  • #40
I just got dizzy reading this post he changed his mind like 4 times thru the post....wow is all i can say...do yourself a favor save for TW heads and be done with it aluminum heads are so much better for so many reasons...
Reactions: TOOLOW91
  • 3
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Q
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
