I've got this motor that was a friend of mine's and we put it in my car, and I don't know if he adjusted the rockers correctly when it was in his car but one of the rocker arms was just sitting in the valve cover when we took the engine out of his car! Anyway I assumed he didn't do it correctly, so I adjusted them the was Comp Cams says so, which is very similar to the instructions I found on here when I searched.
Okay, what's happening is when I adjust them to where there is resistance on the pushrod, then turn the nut a 1/2 turn, on some of them it feels much tighter than others. This worried me at first, but I figured, "well it's what the instructions say!" Okay after I did that, we finally got the engine running, and after a quick test drive we knew something was wrong, and took off the valve covers....TWO of them had fallen off and others had loosened up!!! WTF??? :damnit: So now I adjusted them, but put the ones that felt loose a little tighter, and I also used locktite on the bolts and set screws. Now I drive the car and it has no power at all, and it could be my tune as I am still messing with the Tweecer, but it's really bad, when you floor it it takes forever to get up to speed! I think maybe I overtightened the rocker arms....What should I do? Should I just follow the instructions AND use locktite? The instructions do not say to use locktite so I don't understand why they are falling off! HELP!
