well by george i figred it out. its been in the mid to upper 90s here the last few weeks here in NC, well the car has been running a bit warmer then usual, let me tell ya a bit warmer like on the L of normal for our guages.
well i checked and double checked everything, the ccrm is functioning correctly, i have high and low speed settings on the fan. low speed pulls about 8.5-9volts, the high pulls 13.2-14volts. the high speed was throwing me because with nothing else running (a/c, lights, etc.) it would only pull that voltage. with everything going it would only pull 11.7-12volts.
well it was wrong, its supposed to pull the low to high 13 volt range. with the fan running on less voltage it doesnt turn the correct rpm thus not pulling the needed cfm. so i says well i then tested the alternator with the my volt meter and it put out 13.89-14.13volts depending if the a/c was on or along with the headlights.
with that checking good, i then turned to the battery. from experiance the battery depending on group size should put ou aroun 12.5-13volts with the engine not running. well mine was putting out low 11s. it seemed like it would get harder and harder to start in the AM. the battery only beeing 7yrs old i took it down and bought a new one.
this new battery has 60 more cca. installed it and wam bam the fan pulled the correct amount of voltage, as did everything work like it should. the altenator tested good as well (home test with volt meter).
now my only fear is the starter going out because of the incorrect amperage from the old battery for so long (guessing 6-8mths). i thought i had a malor cooling problem, but turns out its the simple things that make it easy, but sometimes its gotta smack us before we figure it out.
