hi, my stang is over heating and spitting coolant out of the resevuar tank ive changed the water pump-thermostat-and radiator cap...and there is no water in my oil....whats my prob???anybody
Sure the bottom of the radiator isn't clogged up? My stocker looked great looking in from the top of it, but looking in where the lower hose connected was a whole nother story.
ill look into the radiator being cloged...but i just had it off and all the coolant came out of the bottom just fine ..so im not sure....but ill check it
Are you sure the thermostat is working properly. Can you see when it opens with the radiator cap off and is it flowing through the top of the radiator whenyou rev it up?
my stock fan messed up so i put an electric fan on and it heated up a lil more than with stock fan than i put a supercharger on it and thats when it started over heatin
If you use a good electric fan such as a 94-95 Mustang fan then it should cool much better than a stock clutch fan. Could be a blown head gasket. Even if you do not have water in your oil. Also could be running lean and causing more heat.
well its off of a 95 gt but its workin great.....i can heat the car up and shut it off and not even 1 min later i can touch the radiator and its very cool
