Could your probe in the stat housing be affecting the movement of the stat itself?
What is it doing now, I am a bit lost.
It is running hot on the road now? Simply from moving the temp sensor?
I am going to use the shotgun method to point out the high points of cooling in my mind:
Fan shrouding is important around town.
Lower radiator hose must not be soft, and should have a spring to keep from sucking shut and cutting off water flow on the highway.
Fan is not required when traveling faster than approx 40 mph.
Any air deflector placed stock under the radiator must be in place.
Water pumps are only bad when the bearing goes out or something physically BREAKS.
The bearings will either make a heck of a noise, or (more often) cause the weep hole to leak.
The impeller has to break off otherwise for the water pump to stop pumping, and it will stop totally.
Radiator cap must be on tight and hold pressure. The more pressure, the better cooling, but the harder on possible leak points in your system.
Air in the system is no good.
I would look at simple things first.
I also wouldn't sweat where the thermoprobes are. The rear of the engine would be hotter than the front if the flow wasn't the same.
Also, water flow that is too fast will not remain in the radiator long enough to dissipate heat.
This is why you should never run without a stat.
