My Carburetor is singing the blues!!
PickupMan
403
Hazleton, Pa
I've noticed for a little while now that when I come to a stop and the engine idles down I will occasionaly hear the carburetor sound like a horn!!?? :shrug: Any ideas what this could be? The carb stumbles a little around 4500 without kicking in the secondaries. The carburetor is a holley 650 double pumper. Any ideas?
Sounds a little like a vacuum leak. Do you see any discolorations around the carb base? Like it was leaking a little gas and then drying.
I had something similar happen, the carb gasket acted like a reed and would give a high pitched squeal.
That's so funny! A few weeks ago I kept hearing this low air horn noise when I slowed down. It finally got loud enough that I thought I may have a low current short in my horn, but all the honking in the world wouldn't make it go away. Turned out the top tank on my rad had seperated from the core and was acting exactly like the pressurized brass horn on my sailboat! It wasn't hot enough to overheat so there wasn't any steam. I actually laughed when I opened the hood and discovered what it was.
