Ever since I bought my 91 gt when I was 15, I dreamed of owning a Blown Stang, as my user name insists.....well....my dream has come true. I am in the process of finalizing the deal, unless something unearthly happens, should have it completed by next week....2001 Mustang GT-Black with Tan Leather. Mods are below. Car made 360hp/360trq to the wheels at what I was told 6-7 lbs of boost. I will have to take the car to get it dynoed to re-check the tune, boost, and numbers. Drove the car today and fell in love! 1st and 2nd gears are a joke. Nothing but tire spin. 3rd is iffy haha. Best part of the car, has 23,500 miles and looks mint!!!! Pics do not do it justice!
Body
2003 OEM Cobra front bumper
2003 OEM Cobra Hood
2003 OEM v6 rear bumper
2003 OEM Cobra rocker panels
2001 OEM Bullitt side scoops
Wheels
2003 Chrome Cobra wheels with Nitto Tires
Also have 2 brand new 17x10.5 Chrome Cobra Wheels with Nitto drag radials not on the car
Brakes
13 inch oem Cobra Brakes in front with stainless steel brake lines
11.65 inch oem Cobra Brakes in rear
(All rotors are cadmium plated)
SLP Line Lock
Rear
Eaton Posi
31spline moser axles
3:73 gears
Transmission
Tremec 3650
Pro 5.0 shifter
Mcleod Clutch
Steeda Adjustable Clutch Cable, Double Hook Quadrant and Firewall Adjuster
Interior
Autometer Boost Gauge
Autometer Fuel Pressure Gauge
Raptor Performance shift light
Cooling
2003 Cobra Radiator
Engine
Vortech V2 Supercharger
AFM Powerpipe
42lb Injectors
2003 Cobra fuel tank and pump
Bullitt Intake Kit
Denso Iridium Spark Plugs
Accufab Throttle Body
Suspension
Kenny Brown Sub Frame Connectors
Maximum Motorsports 4-Point K-Member Brace
Maximum Motorsports Panhard Bar with Aluminum Rod
Maximum Motorsports Heavy Duty Adjustable Rear Lower Control Arms
Steeda Heavy Duty Adjustable Upper Control Arms
MM Rear Adjustable Sway Bar
Eibach Sportline Springs
Bilstein HD front struts
Bilstein HD rear shocks
Maximum Motorsports Caster/Camber Plates
Maximum Motorsports Urethane Pinion Snubber
Front spring isolators
Rear spring isolators
Solid Steering Shaft
Maximum Motorsports Aluminum Rack Bushings, center drilled
Front Swaybar bushings
Front Swaybar end link bushing kit
Front control arm bushings, urethane
Exhaust
Bassani Stainless Steel X Pipe with high flow cats
Mac 3inch dumps
Body
2003 OEM Cobra Hood
Wheels
Brakes
SLP Line Lock
Rear
Eaton Posi
3:73 gears
Transmission
Tremec 3650
Pro 5.0 shifter
Mcleod Clutch
Interior
Cooling
2003 Cobra Radiator
Engine
AFM Powerpipe
42lb Injectors
Bullitt Intake Kit
Suspension
Exhaust
Mac 3inch dumps
