My first mustang
5.0-sleeper
Liberty
I just bought a 1985 ford mustang it's a 2.3 4-speed
he gave me a '93 EFI 5.0 I've already swap it to carb
and a built C6 street/strip trans i might use i might sell it
but i need to know what all i need to put it in
and what is the 4-speed part number what ever
You want to know what to put in what? Not trying to give you are hard time, but I can't understand the question.
There are many threads on SN for the 4 to 8 swap. Use the search function and read all you like.
well you are going to need a double hump tranny mount for 1 thing. You are going to need a set of headers and a h-pipe and the cat back exhaust from a 5.0L. you need the engine mounts from a 5.0L. You are going to have a hard time installing the c-6. Better to find a auto (AOD4) out of a wrecked 5.0L and the driveshaft. Also find yourself a 8.8 rear end as your car only has a 7.5.
Please sort out the question. Your 85 Mustang 2.3 is easy to swap to either an efi or carbed 5.0. You need the 5.0 engine and trans. While the 4 speed might be able to be bolted up to a 5.0, with the correct belhousing, and may fit a T5 bell, it will take more work that it may be worth.
Your best trans are a T5, a C4 or and AOD. The C6 can be done, but it is supposedly a very tight fit in the trans tunnel, and it weighs about 100 lbs more than a C4. It is a mother to horse up in place. Been there, done that.
You can send all the leftover 4 cyl parts to me, I have an 85 2.3 auto that could use a running 2.3.
