Ever since my original intake install, my vacuum lines have been a freaking mess all over the engine bay. It was due to the fact that the Explorer intake had all completely different vac lines. So I went ahead and slapped this together for less than $20 and organized/replaced ALL the lines and did away with the stock vacuum tree on the fender.
What you see it all it is: A piece of 1.5" ABS pipe, two caps and some brass fittings. I picked it up at Lowes. Right now the only line NOT there is the A/C vent control since my drill ran out of battery power before I could tap the hole for its fitting.
I wanted to make sure the vacuum was balanced so I have two 11/32" supply lines to either side of it. They are mounted in separate sides of the plenum as well. In order from left to right: supply, purge solenoid, red plastic line (spliced), driver side fender vac line, FPR, brake booster, supply
Notice the sweet dangling alarm it's fully adjustable now
I wonder if the added volume will have any negative affects
If so, maybe I'll make it maller and hide it away. I was also thinking of revamping it for the purpose of redundancy and maybe run the brake booster to the plenum itself.
Anyway, just thought I'd share for no good reason.
EDIT: I may re-route the line to the canister purge solinoid to tee off of the supply line. I'm not sure that's necessary but we'll see.
If so, maybe I'll make it maller and hide it away. I was also thinking of revamping it for the purpose of redundancy and maybe run the brake booster to the plenum itself.Anyway, just thought I'd share for no good reason.
I can see someone bringing it to the next level....lets say something in Aluminum and polished...
