Just thought I would share my progress and my procedure for installing my intake manifold. Occupy some of my free time lol.
A key thing I done that helps a lot with reinstalling is labeling everything you take off. Extra time spent here will save you a headache during reinstallion. Especially if you plan on leaving it for a few days, theres quite a few connectors and vaccum lines that could confuse you. For the most part it's pretty obvious, but better to be safe than sorry.
I disconnected the battery to keep it from draining and since you'll be messing with the wiring harness a lot, it's a good thing to do.
Next I removed the rubber tube that connects the throttle body and the MAF sensor. After that I took a Torx #9 bit and removed the intake plaque to access the two upper-lower intake bolts. After that I drained my coolant. It's necessary to drain it, so now was a good time to do so. Once that was done I began work on disconnecting my sensors. I unplugged the IAC and the TPS sensor, and almost forgot the one underneath the EGR. Kinda tough to see lol. Once that was done I removed the accelerator cable. It's kind of tricky to figure out, but basically I used a screwdriver and very carefully pried the little metal tabs in the plastic while gently pulling it away from the little ball that connects to the throttle body. Once that was done I removed the cable bracket that attaches to the throttle body. I don't remember the size I used. Then I removed the PCV hose on the egr spacer and the two little rubber coolant lines that run on top of the egr spacer. They were a tight fit so it took a little twisting and the help of a screwdriver to remove them. After that I took off the throttle body nuts with a 1/2" socket. They were on too tight to use a 1/4" so I switched to a 3/8" ratchet and they popped off. The throttle body slid right off, but the egr spacer didn't want to come loose. I lightly tapped it with the heel of a screwdriver and it slid off. It contained coolant so I had to be careful to keep it from spilling. It will spill a little however. Using the sharp edge of a screwdriver will only bite into the metal and won't do a lot of good. A few light raps in the direction it needs to slide off should work it loose. Once that was off I started removing my upper intake bolts. A 13mm socket worked well. On the back passenger bolt, there is a bracket that mounts on top of a stud/bolt. It will have to be loosened to access the actual stud/bolt that holds the upper intake on. It is also a 13mm socket. I need a long extension to reach it. It's on the back of the lower intake, and very hard to see. A good flash light and feeling around really helps though. I didn't remove the nut since it would be nearly impossible to not lose it. I loosened it enough to slip the bracket off and out of the way and removed the bolt. There is another bolt on the drivers side at the back that is hard to reach. Then two more at the front, one behind the distributor, another in plain view just inside the fuel rail on the passenger side. After removing them and the two on top, it was time to work on the vaccuum lines. There is a vacuum line that runs under the front of the upper intake to the charcoal canister. There is a clamp that holds this hose on so a set of plier will be needed (or really strong fingers) to loosen this clamp and pull it back. Once the clamp has been removed you need to slowly attempt to twist and pull the hose out. It's a pretty fragile hose, and if yours is like mine has already shown signs of wear. If in doubt, replace. There is another right beside it, but don't bother removing it yet. It simply reconnects to the upper intake so spare the fit of removing it until the upper is off the car. Follow the line though, as it runs into a vacuum tree under the drivers side portion of the intake. On the other side towards the firewall, there is another line that will need to be removed. It runs to the PCV I believe. Also there is another vaccuum line just to the side of it that connects to the black vaccuum tree mounted on the firewall. Spare yourself the headache of removing it under the intake and remove it from the vaccuum tree. Be careful though, as the tree could possible crack if you are aggressive with it. Patience is key. After that there is another little vaccuum line that runs in from your pressure regulator. Remove it and label it if needed. Your upper should then be ready to remove. Manuever it from it's area and out from the car, and set it to the side. Once out you will be staring at what seems like a mass of wires and fuel rails. I took a break at this point, since there are a lot of little things to deal with. The plastic connectors have some age on them and are fragile. Be careful. Next I began unhooking the injectors from the wiring harness. Take a small screwdrive and carefully pull one tab up will tugging slightly. That side should be unclipped. Rotate the injector and repeat of the other side. The other side may slip back into the locked postion. If it does just play with it for a few second with a LIGHT wiggling action and it should come free. If it doesn't pop the little tabs loose again and retry. I got seven injectors loose. The last one is under the fuel pressure regulator and thats what is next on my list to do.
I'll continue tommorow night once I continue my progress
Just thought I would share my techniques/progress with you guys. I hope it may help someone with their install. I've read a lot of articles with advice and just thought maybe I'd be able to help the community a little bit.
