So it's been a while since I've posted anything here... Been busy with this car, and last week the motor let go, after turbocharging it.. Not sure what caused the distruction, but I'm more concerned with getting the tune down this time.
New motor going in should be here Mid week, along with the support parts, the head is at the machine shop getting valves, cleaned up, ect.. Turbo pipes are off to the local coaters tommorow, still have alot of detail work, some more paint, and the engine install to go.
Livernois Motorsport 4.6l - Cobra crank, Manely H beams, Mahle pistons, Cobra oil pump, Clevitte bearings, balanced.. Cometic MLS gaskets, ARP head studs and Main studs, ect... 42lb injectors, Focus pump with BAP, Lighting 90mm maf, and SCT X cal II tune..
BEFORE:
AFTER:
CURRENT:
BEFORE:
AFTER:
CURRENT:
Primo stuff as usual...
