You're wrong. LS motors are hard running motors, but the cheapest way? No. 130 mph traps shouldn't be a problem with 500 rwhp. That can be done with a 302W for much cheaper than an LS swap, especially considering you probably already have the motor and the computer, but I admit that you'd be running the possibility of splitting the block. A built 351 would be a better way to go. Start with a $100 junkyard block and pick your poison: n/a stroker, nitrous, blower, or turbo. The LS1 definitely has advantages over a motor like this, but cheaper isn't one of them.
Chris
I don't think there is any way, you can personally put together a ground up build from a 100.00 junkyard 351, and build it to the power level (and durability) to make 500 whp for 3000.00. Even if you do have a rabbit in your hat, and you ebay build yourself a miracle stroker w/ all internals, heads, machine work, and induction for 3k, @ 500 whp It's still a main saddle crack waiting to happen.
I HATE LT series SBC engines. I Hate them in mustangs, hell I hate them in the cars they came in. But after owning several Holden based GTO's w/ LS engines,....I love those things. (the engines). But just as much as hating a SBC in anything, I'll take a pass on the sameness that an all-mustang car show w/ the same 5.0 w/ mods, blah-blah-blah snooze fest that typically happens all across the country.
The
Car doesn't take offense that it has a different engine in it. If the car could think anything,
it probably loves going 10.ohs for the first time in its' life.
Coming from one guy that puts ford engines in cars they don't belong in, to Zapp I say: more power to you. You got up on the
other side of the bed and proved it could be done. AND You didn't even have to brush your teeth w/ your ford blue toothpaste, put on your Mustang undies or your I hate chevy T-shirt to go out the door and get on w/ your life either.
